One of the missing items from my bike is the Petcock I think it was removed when the tank was sent for chrome.
Can anybody point me in the right direction as to the correct version for a 1956 Dominator 99?
Then the joy of de rusting the tank begins.
Craig
I bought one of these -…
Thanks, the tap with the…
Thanks, the tap with the reserve is out of stock do you know what thread it is?
Usually 1/4 BSP. ( which…
Usually 1/4 BSP. into the tank, ( which looks far bigger than 1/4 !! ) but thats the way it is.
If you can only get a 'Main'…
If you can only get a 'Main' you can remove the filter mesh, cut down the metal tube and then refit the filter mesh so the tap effectively becomes a 'reserve' allowing more of the fuel to be used.
I will have a look around…
I will have a look around the specialists see what is available.
I can buy one from the shop they are cheap enough and replace at a later date if necessary.
I bought one of these - 033155 from the NOC shop for my 1958 '99 as it looked just the same as the leaking one the bike came with - it fitted fine, seemed very reasonably priced. If you only have one tap then buy a 'Reserve' one as the 'Main' one doesn't let you get the last bit of fuel out.
