Gents,
I will soon be in the process of removing head and cylinder on my 46 due to bad head gasket...yes a copper head gasket. PO who rebuilt it used a head gasket instead of lapping...I'm assuming...hopefully it's ok?
Could someone recommend the the grit# for fine and coarse for me so I don't waist my time and money?
Thanks.
Valve grinding paste, sold…
Post WW2 the factory used a…
Post WW2 the factory used a gasket anyway - probably cheaper - less labour.
Which begs the question: when lapping with coarse and fine, the outer surfaces must have a very small gap. Do the head bolts close this up?
But if a gasket is used, the gap will be wider (thickness of gasket) unless the machining is different. So does it close up? If so, is there a danger of breaking something? Or am I over thinking? If they machined differently, the later engines wouldn't be suitable for lapping in because of the space for the gasket.
You're supposed to use....
.. fine paste on the actual head joint, coarse on the outer area. You should end up with a minimal - a couple of thou or so - gap on the outer area ensuring that the head joint is pulled down. I like a very thin coat of wellseal on the outer area to seal the oil drain.
I still have my original tin of valve grinding paste as I never use much.
I will give it a go on the…
I will give it a go on the lapping. The PO used a copper gasket but I don't know the condition yet since I have not pulled apart. The only reason I'm doing this is because when the engine first starts I see/feel air/oil straight out the joint blowing toward the mag. After about 20-45 seconds it's gone and seems to run fine otherwise.
Am I making a bigger deal out of this than I should?
Valve grinding paste, sold in the twin tub, course one end fine the other
