Thread story
Hello,
Trying to pull the oil pump out, and heard that two 9/32 x 26 tpi screws would do it.
But is it BNC, BSF, BST, BSP, CEI, UNF ...?
Thanks for your help.
oil-pump-screw-to-pull-the-pump-out-jpg
Hi Christian
26 tpi would be cycle thread BSCY 9/32 is a strange size bicycle crank cotter pins used to be that size
Regards Roger
Thanks Roger,
I've read that, cycle thread, somewehre else and was just looking to confirm.
Regards,
Christian
The measure 9/32 "(7,143mm), 26 threads per inch corresponds to the BSF system (British Standard Fine).I find it strange, but I do not rule it out.
Greetings Gerardo ....
I have a feeling that 9/32" BSC screws are the same size as those used on Dominator Twin rocker adjusters.
Even more irrelevant, BSC 9/32 is close to the quite unusual thread M7. Which has 25,4 tpi.
Why not use 7mm x 1.0 pitch bolts? They are only 4 thou smaller in diameter so only 2 thou smaller on thread depth than 9/32 and taps and dies are readily available and not very expensive. At a pinch you could tap the pump to 9/32 x 26 and still use a 7 x 1 bolt. In one inch of engagement it would only be out .6 of a thread and as it is minutely smaller would probably screw in at least half to 3/4 of an inch. This post will be too late to help Christian but may help others.
P.S. 7 x 1 bolts are available from your friendly Honda dealer they are rear chain adjuster bolts for CB400 fours and about 2" long from memory.
C'ya Bill
Bill has a good point about where to find M7 bolts, because(annoyingly) M7 is a non-preferred size.  M6 and M8 are easy to find.  M7 is used in mass produced machines, since if you make tens of thousands it is worth going non-standard, but otherwise they are hard to find.  Incidentally: if you want a correct looking wing nut for rear brake adjuster, you can use the NOC wing nut which has 1/4" (post war maybe?) thread, and drill it slightly and tap 9/32".  But first find your 9/32 tap...
Bill, also the degrees of inclination of the thread steak further favors the metric adjustment of 7mm (60º against 55º).
Greetings, happy holidays , Gerardo
At this size BScy and BSF are identical
I had to buy the special taps when I made rockers for my flat tankers but I second the possible use of M7 x1 for your use.
