I am having trouble sourcing a composite head gasket for the spigotted head/barrel on my 56 Dommie. It has been suggested that there is not such a thing because there is insufficien space between the spigot and the studs. Can anyone confirm or contradict this suggestion? TIA.
Yes, this is assumed to be…
NOC spares shop, page 6 …
NOC spares shop, page 6 Engine parts £7.50, Is that what you need?. Have to say that leaks happen if you don't tighten down 3 times ,and if it still comes loose throw away those cheap SS head bolts and fit the old plated bolts!. Use a sealer round pushrod tunnels,oil drain and stud/bolt holes.
Yes, this is assumed to be the case, though on the 850 the gap between the bores is small but uses a composite gasket. It maybe possible to make a composite gasket theses days that would do the job, but the copper version works well.
