Camshaft bush removal drive side.
Has anyone removed the navigator camshaft bushes - drive side. Mine are out of round and I would like to replace them, I have tried heat and slamming, about to try and put a thread in them to use a bolt to pull them. Has any one done this and how did they do it.
Andrew
Ive recently had to remove the inlet camshaft bush on my ES2, Andrew, and did it by placing the timing cover in a hot oven for 20 minutes or so then tapped it out. If your one is a"blind" bush it should come out with the slam dunk method. Best to use a cooking bag unless you want the kitchen to smell of Castrol Casserole for a week. George
Thanks George - cooking bag a very good idea, wish I thought of that yesterday, wife a little bit quiet today. What gas mark did you use? i took it upto 6 and no luck after 1/2 hour.
Another option is a coarse threaded tap with a correct nut plus washer, screw the nut onto the tap all the way one followed by washer a short length of tubing that the bush OD will fit into , screw the tap into the bush a couple of turns to get a grip and then wind the nut down and it will draw the bush out inside the tube.
Thanks John, looking that way I think.
Just been thinking a bit more, if you put a smaller washer/disc in the bottom of the hole to protect the alloy you can screw the tap in without the nut/tube/large washer and once it bottoms out it will pull the bush out.
Hello John,
that is an interesting plan, while waiting for a suitable tap, I have tried to solder a piece of tube in place, with a washer behind with bolt and nut to use as a jack, solder did not take, but trying epoxy. I don't expect that to work either but will try while waiting for a tap, tricky size as it turns out. I am beginning to appreciate resolving this kind of snag is one of the pleasures of getting an old brit back on the road.
Sorry Andrew , I can't remember but there is more about it on this site. Look under camshaft removal. George
Thanks George, it seems that if the bush does not come out with gas 6 and 30 mins, then it is out with a hack saw. Hoping to avoid that, but obviously these were not what you might call service items. Onwards..
Its out, for those who need to pull this bush, I made a small extractor with a piece of 1" copper pipe, 3 penny washers, 5*50mm bolt, three nuts, and an old valve spring (though I don't think that was needed).
I have attached a very simple drawing of the extractor but in essence I epoxied a short length of copper tube inside the bush, with a washer at the head of a bolt behind it. Waited three days for the resin to harden, then with a combination of valve spring and spacers to stand the spring off, and allow the bush to rise through, the bush came out as the spring was compressed. A very rough sketch attached, and if anyone wants one, I will try to photo later - not my strong point though.
navigator-camshaft-bush-tool-png
