1970 Commando S type rear mudguard Part Number 06-1173
See below application for commissioning of a part. If you also require the same part or know where they can be obtained. Please respond accordingly.
Note:- The NOC does not possess a drawing of this part.
Description of Part Required
Model Number required for.
1970 S type
Part Number
06.1173
Also used on if known.
Many also be on earlier S or SS type ?
Implication of lack of part
Vehicle Off Road
Routes you have tried to acquire the part and response received.
  1. Spent the last year to two years trawling ebay, members groups, forums, and contacting anyone I can think off, I did try the 06.2172 to modify, but I can’t make it work – there do not seem to be any available, but I have had contact from others also searching
Do you have a worn or damaged part available as a pattern?
I have access to one virtually new from a member
Based on price for similar parts, what would you expect to pay (give range)
I would not be surprised to find £250 or so for a good chromed version, as per original spec
Comments
This is holding up a build, the bike can’t be completed at all, I have looked at and tried pattern parts, but none have the correct mounting holes or profile (I can “get over” the profile, and could get holes re drilled and welded over) but this mudguard also has the indent along the top side for the tyre pump, and has a flattened section immediately behind the battery box, these 2 unique features make a pattern part a “non starter”
