I am sure I am not the first to use UV light to pinpoint oil leaks, I thought I would share this photo just to show how well it works. The torch is about £13 on Amazon.
I have one similar...
Luckily oil is naturally…
Luckily oil is naturally luminescent, so just shine the light on the engine.
Thanks for posting this…
Thanks for posting this great idea!!
... that I used to find coolant leaks on a car. I had to put some sort of UV luminous fluid in the coolant - did you have to do the same?
