help can anyone tell me where I can purchase a set of cam followers and push rods for a model 18 engine . I'm after the push rod tubes as well
Thanks Ian
Depends on the year...
Part number???
Ian:
If you will provide the part numbers I will check the parts sources here in California for you.
Thanks Mike not sure if part…
Thanks Mike not sure if part numbers But I'll try and find out then post them here
Thanks Ian
... but worth a trawl through the used parts lists here.
