When I ran the clutch cable to the gearbox it wanted to go between the 2 oil lines which is where I ran it, and it is up against the inner oil line after running it for a few hundred miles.
Looking at a picture of a Norton the clutch cable is run outside of both oil lines.
Where is your run, I worry about it rubbing.
Hi John, Yes,…
Hi John,
Yes, between the oil lines. It might be because of the run on the inner oil line. Might need shortening or pulling further onto the engine oil pipe.
