My headlight shell is in a sorry state, but I think it can be recovered with some fabrication and welding..
The hole for the ignition switch has been hacked out, and a generic lock was put in. I want to restore it to fit the standard Wipac switch. Is the D shaped hole the same as the one for the light switch, or is it a mirror image?
The headlight was held on with bolts and nuts, U.N.F. (Ugh). Should it have captive 5/16 B.S.C. captive nuts?
The bike is a 1964 Electra.
TIA for information.
Colin, trying for only one size of spanners to fit everything on the bike.
Hi Colin, just had a look…
Hi Colin - you seem to hav…
Hi Colin - you seem to have two identical postings on this. If the Electra has the same Wipac 6.5" headlamp shell as the Navi De Luxe like mine, then it will have 5/16" BSF captive nuts, not BCY. I found out when trying out some chrome BSA headlamp bolts which are 5/16" BCY and they don't fit!
Previously wrote: My headl…
can you write me at <lighttwins@nortonownersclub.org>
I can take you through it in detail.
Have not time to read all the threads at present - unsure where you have got to
Hi Colin, just had a look at my Jubilee headlamp shell and it looks like the holes are round on mine. I have never had any problems of the switches turning in the shell. Also I am afraid my headlamp is held on with metric bolts so I cant help you there!
