A number of questions about my 850 Mk.3
If any of you follow Accessnorton these may be boring repeats: Is there a standard screw pattern for front master cylinders to attach it to the switch cluster or is attachment of a "foreign" master cyl. a custom job? With Avon AM26's, is there any interference issue on the front with a WM3 wheel and 100/90 x 19 tyre? Thanks!
I think you have to replace the switchgear with something else. Have a look at Andover Norton site for their solution. On tyres I use AM26 100/90-19 with WM3 and clearance is fine.
The mk3 master cyl is attched via four M5 screws length 45mm - quite rare to have metric threads on our Nortons!
