Dominator Headlights
My 1960 Dommie headlight shell has 3 holes on the underside.  1 off 1 1/2" - main harness and one 1 1/8" and one 7/8".
One is for the speedo cable (I assume), what is the third one for?
I think the other is for the dipper switch / horn mini-harness from the left-hand end of the handlebar.   Cheers, howard
The small hole is for the speedo zero setting rod/cable for the odometer.
Aaaaah   thanks. It must have been lost in antiquity
Steve
Oddly the larger 1.125" hole seems to be for the trip reset, and the smaller 0.875" is directly in line with the speedo drive cable.
I ordered 28mm and 22mm blind grommets.
Steve
