I'm hoping to fit some exhaust kick-ups to my Navigator and as a result the nearside silencer may foul on the rod connection for the rear brake. I may need to do some creative fettling!
The cam lever on the rear drum currently points 'down' if you get my meaning, and rotates the cam clockwise, but I wonder if it could be flipped to point up and pull anticlockwise? This might give me the clearance I need. Alternatively has anyone ever ditched the rod altogether and made a cable connection?
Regards,
Nick
Cable connections work fine,…
Cable connections work fine, but you may need to be creative with the brake light switch
Dan
