Navigator oil leaks
Hi I am fairly new to the norton navigator and bought a non runner last year. I have rebuilt the bike but left engine till I had chance to start it before doing any repairs. I started it today and it runs very well but I have two major oil leaks. One is coming from between area were front sprocket is (also leaks around alternator wire grommet caseing joint) I will strip this side and investigate. My big concern is the right hand cylinder head, after running it leaks from what appears to be between the fins at the front well above the head gasket, I cannot see any oil leaking from the rocker covers or the oil feed pipe. Is it possible the casting itself is leaking. Any help would be most welcome. Keith
