Lightweight headlight shell
My headlight shell is in a sorry state, but I think it can be recovered with some fabrication and welding..
The hole for the ignition switch has been hacked out, and a generic lock was put in. I want to restore it to fit the standard Wipac switch. Is the D shaped hole the same as the one for the light switch, or is it a mirror image?
The headlight was held on with bolts and nuts, U.N.F. (Ugh). Should it have captive 5/16 B.S.C. captive nuts?
The bike is a 1964 Electra.
TIA for information.
Colin, trying for only one size of spanners to fit everything on the bike.
can you write me at <lighttwins@nortonownersclub.org>
I can take you through it in detail.
Have not time to read all the threads at present - unsure where you have got to
