Jubilee ignition switch.
I have a new motorcycle ignition switch 30amp rated, four position. Thinking  of fitting it in the side panel. Can I run the live from the battery to the switch and then take a switched live out from the ignition switch and join to the brown wire in the loom or is there a better way. I just want to interrupt the battery only. Its been converted to 12 volts. Never liked the idea of the on/off headlight ignition switch, anyone can turn the switch on, kick start it and off they go. There has also been a number of times where someone has fiddled with switches and Ive come back to a flat battery.
John.
If it’s been converted to 12v the I\E switch is not needed if you have an ignition switch, so why not put the ignition switch there ?
This is a deluxe model. I want to keep the bike as original as possible. I did think of putting the switch in the headlight but the bottom part is quite large. I like the idea of putting it in the side panel as it curves towards the carbs, just above my right knee and near the battery.
John
You say this switch is 4 position. So why do you need 4 positions? Perhaps you mean 4 terminals? But if you have a simple make/break then fit it as you describe.
Dan-your description of the I/E being not needed is not quite right, what you mean is, once converted to 12V the Emergency ignition function is lost.
Thanks Al.
Yes I do mean four terminals. Yes there is a make and break on the switch.
Regards the I/E switch. My bike will only start on the emergency position, no spark at the plugs on the over side of the switch. Have I wired it wrong. It starts and runs ok.
John.
Maybe....As it happens once you have gone 12V with these machines, the Emergency start is defunct. I am under the impression that it should start either way on the ignition switch. But of course whether it starts on alternator or battery in the emergency position I am not sure. BUT it should start on the Ignition position from the battery. A test you could do, if the bike is 6 V. Disconnect at least two of the alternator wires. Then see if it starts, if it does then it is starting on battery. If not then it is on alternator. Either way this does not seem right, I am investigating the problem, we will be back!
I am back, after judicial investigations ie read the Norton Manual! On Emergency position the alternator is connected for full output to the rectifier thus boosting the Battery voltage. So with the 6V system the bike will/should start in IGN and EMG, with the battery applied to the coils. BUT in the EMG position the alternator is connected for full output to the rectifier and thus to boost charge the battery. Especially useful when the battery is low/flat. But do not continue in EMG for too long (10 mins)
In your case John if you can only start and run on EMG and your switch is wired correct then you will over charge the battery in a few miles. But you might have lost a switch function (inside the switch) or you have the switch wired 'gobbledegook' in which case 'over to you'
Of course if you have 12V then all this is quite insubstantial.
In reply to by alan_osborn
Thanks Alan
It is 12 volt Sure Fire, fitted it over two years ago. Its the first time Ive started the bike in over six months. Got a feeling that it might have started on both sides of the switch previously, but at the moment it will only start on the emergency side. I will have a look at it over the holidays, see if I can see anything wrong with the wiring.
Al, it’s unusual that I can add anything of value to an electrical discussion but here goes! .... My comment about the I/E switch not being needed if you switch to 12 volts and an ignition switch  was not well described, what I meant was the I/E switch is effectively an unlocked ignition switch, so in my opinion it would be better to replace it with a locking ignition switch - simple on off - rather  than drill a hole in a panel for a second switch. If you were really clever perhaps it would be possible to glue the Wipac knob to a cut down key shaft so it looked like the original switch when it was inserted.
Interestingly (Or not!) I have converted to 12v and fitted a new replica Wipac switch, mine switches on the ignition in either I or E but the “I” side of the switch is a bit flakey and sometimes doesn’t connect, so I use E. My guess is that so long as John’s switch is wired ok that it is a “bit” defective like mine!
Dan
Yes Dan you are right (for once!). This is exactly the situation with the IGN-EMG switch. They get 'flaky' and it is best to fit A N other.
Now I tell you a Story- On my Electra, electric starting is limited to decent battery power. Which of course is limited. SO as we have Boyer Bransden ignition then voltage when starting can be an issue. SO I fitted a traditional toggle switch for the ignition that by-passes the dodgy Wipac switch and also the voltage drop on the ammeter (and tired wiring). This gives me 0.5V extra at the ignition when under electric starter, it works better. But the ignition load is not seen by the ammeter-no problem.
Hi guys
Thanks for your inputs.
I purchased the ignition switch from 12 Volt Planet. The rear of the switch is 38mm width x 36mm depth, so there is no way that will fit in the headlight. I also want to keep the bike (headlight) looking original as possible. Ive now fitted the new ignition switch in the side panel, plenty of room behind the panel, it looks good. As stated above the battery live now goes directly to the new switch and then the switched live goes to the brown wire, the brown wire would normally be connected directly to the battery. Except for a short wire going to the new ignition switch the entire wiring system is now disconnected from the battery after switching off.
This is mainly to stop opportunist thieves
John.
John-Stealing a Jubilee? If it were a young opportunist, would he know how to ride it, even start it, after all the bike has a 'kick start'. But of course crap head kids do fiddle with light switches etc.
