Good afternoon all,
Question?Exhaust pipes glowing cherry red,whats your money on?incorrect ign timing or weak mixture?
Glowing exhausts
It's not a gamble. Set the…
It's not a gamble.
Set the ignition correctly, then follow the carburettor tuning procedure.
just a bit of fun michael
Pattern Parts
Some pattern exhaust pipes are made of such thin tubing they will quickly go red hot when the engine is run hard.. Any Chroming will then turn blue. Then they start to rust.
Below are my cheapo replacement pipes after just 20 miles.The previous standard Armours set had covered 10,000 miles and were in perfect condition but I wanted some swept backs.
The Ignition Timing and Carb settings were not changed.
Pictures of down pipes on my…
Pictures of down pipes on my Commando after 1,500 miles still look new now with 2,100 miles on them. Bought off eBay. I did internally coat them with 5 coats of Kreem Blue before fitting.
Sorry looks like pictures…
Sorry looks like pictures exceed 5MB limit so will not post.
Only seen red glow once
On a 1930 Ford model A with distributor fitted wrong way. Ignition timing my bet.
Red hot!!!
Just the once when the ignition timing slipped. Blued exhausts are different - often an indication that the bike is being used to its full potential.
Retarded ignition
Flame front is running down the pipe because ignition was too late...
J
So you think you've got problems...
This is what happens when the exhaust valve sticks open on a 16H...Yes, it was glowing red there when I stopped.
Ignition timing
