Camshaft bush reaming
Hi All.
I am currently rebuilding a '75 850 mk3 and have fitted replacement camshaft bushes, as the old ones were quite worn. I was reluctant to do this as I know that replacements should be line reamed, but the clearance in the old bushes with a new camshaft was too great to ignore.
Now that I have fitted the new bushes, it is evident that they will definitely need reaming. I don't have the facilities to do this accurately and wondered if there was anyone who had the facilities that could help? I have approached a few local machine shops and none are interested in doing the reaming. I am based in Dorset, but could travel if required.
Thanks in advance!
Try T&L Engineering in Bedford, as they do all this type of bike and car engineering work. They also do the K Line relineing of valve guides, so that you do not have ot replace your valve guides.
Norvil are currently doing this for me - not got the cases back yet though!
Norman White did mine at his Thruxton workshop. Not sure if he is still doing customer work, though. Does anybody know?
A quick edit. Just checked his website, http://normanwhite.co.uk and all seems ok.
