Frames
Hi, can anyone tell me if the 1972 Interpol frame is the same as the Interstate frame? Due to arthritis, I'm planning on converting my 750 JPN replica to an interstate, with an easier riding position. The JPN replica started off as an Interpol way back. Basically, I need to know if the Interstate  seat and fuel tank will fit properly.Thankyou for your help.
Norman, no issues I can see. Also with your arthtirits surely a Roadster would be better, the interstate is heavy when full of fuel.
All Commando frames are interchangeable as far as tank, seat, engine etc. mounting points are concerned. 850s have different steering geometry from 750s, later frames have reinforcement for the rear loop and some variations on stands but thats about it.
You might find that Interpol spec. works really well for you.
Here's a tall guy on a Roadster (actually S-type):
Clint
Interstate kit will be fine on anything. Some later 850s had a slightly wider rear loop and won't accept a fastback tail, but that's the only exception I've ever come across.
