Does anyone know where I might get a rear wheel sprocket for my 1928 CS1 with the enfield rear hub?
If your hub is the same as…
If your hub is the same as my 31 model 20 you can have a sprocket fitted to the old one.
My machine shop removed the old sprocket at the Fingers then welded the new one on .Perfect
The Scott sprocket is close to mine but the offset is off a bit.At worst I'm not sure if heat and a press might put it right.
