AMC Clutch / Primary Drive Options
Hello all,
Hope everyone is well. I am currently building a triton slimline special, which will eventually house a dominator engine once funds allow some Maney / Molnar engine parts.
I have a dominator gearbox from a 1960 650SS, rebuilt by Dave Coates which has the RGM close ratio gear kit.
I am looking for recommendations from anybody who has used either a commando style clutch and belt drive with a dominator box, or stuck with the dominator clutch with the kush rubbers and primary chain.
My main goal here is to find a good solution that will not kill my gearbox for general fast road use.
I absolutely do not want a primary case filled with oil. I am going for the road racer style, and want to have an open primary.
If you were in my shoes would you run a dominator clutch with open chain, or a commando clutch without the kush rubbers and a belt drive?
Am I destined for gearbox ruin if I use a commando clutch and get rid of the kush to run a belt drive?
Why does nobody make a dominator clutch with a belt drive kit? Seems like a gap in the market to me...
I understand that I will need to use a sleeve or change mainshaft for commando clutch.
Any advice would be much appreciated.
The Commando conversion generally gives a lighter clutch action.
Belt Drive 2
Belt Drive 1
Is that a dominator clutch with a belt drive outer? Does it retain the kush rubbers? I cant see any rubbers from the picture, but if so... where on earth can I find one of those! :)
