ES2 1960 clutch friction plares
Hi, anybody in the Hampshire area know of a company that will supply & fit new bonded friction pads to my existing ES2 clutch plates? I’m rebuilding my bike after being boxed for 40yrs , the pads are dry & some are detached hence new pads required
In NOC spares you show a clutch back plate less friction pads part no. 040353 where can I get the friction pads bond to this plate?
I think (not sure) the 1960 clutch uses all factory bonded friction material  and  replacement plates are the norm. .Its possible that you have an earlier clutch which could have some  pads replaced  and this is causing confusion ?.
