Having watched Mick Hemmings excellent DVD a few times I notice that he fits the thrust washer (A2/328) direct into the the main gear wheel (with the roller bearings). The good book, on the other hand, shows a retaining washer (Plate TN12 but not given a part number. I'm assuming it's A2/319 - "main gear wheel sleeve bearing roller retaining washer") between the thrust wash and the roller bearings.
Is the retaining washer needed or not?
Help!
George
BTW - I realise all this…
Possibly depends..
.. on which type of box. As far as I know, the thrust washer is only fitted to the upright / doll's head / laydown boxes. In which case, the retaining waher is necessary.
Laydown, Ian. So if I…
Laydown, Ian. So if I understand you correctly it needs the retaining washer?
g
Well done Ian. It's g/box…
Well done Ian. It's g/box rebuild day today so I'll do as you say and see what transpires. Many thanks for your help.
George
BTW - I realise all this cropped up a few years ago but that thread didn't address the query as to why a washer is shown in the diagram but Mick Hemmings doesn't mention it? Very confusing!
George
