As I know nothing of the history of the engine I have, could anyone give me the dimensions of the cylinder barrel height - From base to headgasket face?
And while we're at it I have a RH10 cylinder head - how deep is the combustion chamber from the gasket face?
Can’t help with the…
I measure barrel height at…
I measure barrel height at 115.7mm. I believe this is original. Another barrel, which has been fitted with liners and hence likely to have had a light skim, has a height of 115.5mm.
I would note that the pistons stop short of the top of a standard barrel fitted with standard base gasket, being about 1mm below the face - from memory 'cos I don't have one to measure right now.
Brilliant - Thank you Stan
Imperial Heights
The attachment is from the original Dominator Service Notes and shows the respective deck heights in inches.
Can’t help with the information you require but if you are trying to identify what CR you have , the most reliable way is to measure the combustion volume at TDC and compare to the swept volume . Use oil and a burrett
