Are there any special trix to avoid dragging clutch?
Assuming all else is right,…
What gearbox and clutch?
Hello Goran,
It would help if you mentioned which bike/model you have. Does it have a laydown, dolls head or AMC gearbox? Conventional clutch or diaphragm spring clutch etc.
Without knowing this it will be difficult to get you a clear answer
Regards,
George.
It is a dollshead model 18…
It is a dollshead model 18 1938
How badly does it drag? They…
How badly does it drag? They pretty much always drag enough to spin the rear wheel on tickover after starting on the rear stand, but not usually enough to affect gear selection.
It is hard to go from gear 1…
It is hard to go from gear 1 to neutral
Some roller races for the clutch body contains 15 rollers and some contains 20 rollers
from which year did they change the number of rollers?
Too much oil, buckled…
Too much oil, buckled plates, poor adjustment , drum flopping about on slack bearing.notched hub, tight chain
t cant answer that one, but…
t cant answer that one, but I found 3--4 thou clearance so i fitted new plus one thou rollers and removed 2 thou clearance. that helps to restrict the amount of wobble the clutch body has when the clutch is lifted. A good clutch is dependant on many factors and a collection of seemingly insignificant small improvements add up to a satisfying snick into first gear , (well----most of the time ).
Where do you get them?
Robert,
Where do you get these these over sized rollers?
Also how do you measure the wear? Or is it just suck it and see?
Don Anson
Melbourne
It could be excess end float…
It could be excess end float in the box. I'd have to look it up to remind myself. Hopefully someone will correct me if I'm wrong. There are two potential places. The sleeve gear/clutch end float can grow when the bronze thrust washer between 4 and 3 gets worn. The clutch then moves too much. And/or the first gear pinion on the main shaft has the shaft end float controlled by a pen steel washer. The WD16H manual gives gearbox maintenance instructions, although I think not actual end figures. (Nowadays everyone loves numbers, but that used not to be the case!).
The bronze thrust washer is only accessible after the clutch is removed.
I'm with David,
that thrust washer is often worn. Easy to check by truying to move the clutch body in & out - there should be just perceptible movement. The other suggestions are also well worth investigating and don't need a gearbox strip.
My first Norton back in 1972 was a 16H that had about 1/8" end float due to said thrust washer. Neutral was impossible at a standstill.
The 3/4 thou drum bearing…
The 3/4 thou drum bearing clearance was measured with a feeler gauge , I have a memory of having to mount the the clutch center backplate reversed to get at it ,but It was a long time ago ! .Oversize rollers were bought after a long search on the internet. I may still have the package with suppliers details. Had to buy 50 rollers. The spare rollers will go in the Atlas when I next "fettle" the clutch.
Assuming all else is right, before you start the bike, pull in the clutch lever and work the kickstart a few times to ensure that the plates aren't sticking together, never does any harm.
