Electric on Dommie model 7, '53
Folks,
I am in the final of my Dommie restoration, the engine start and run well.
How is the best way to check dinamo/magneto works as expected ?
Any suggestion ?
... the magneto is probably fine. The dynamo is a totally separate electrical device - do you have an ammeter fitted?
These are two totally separate machines. They just happen to be mounted on the same platform and they are both connected 'mechanically' to the engine. The magneto produces a spark that runs the engine, if it easily starts the engine and does not fade out after a few miles (when it gets hot) then chances are it is good condition.
Dynamo-this charges the battery which in turn runs the lights (and horn). The output of the dynamo is controlled by the regulator, it can be original with coil/bobbins and points or modern electronic.Readings from the ammeter on the bike are not to be trusted. The battery voltage is 6 rising to 7.5V on charge. (12V-14.5V). Read it with an analogue meter. Cheap digital meters give random readings as they pick up ignition. Or a decent Automotive digital meter. Any dynamo that has been out of use for some time might need 'flashing'. Disconnect D and F at the dynamo. Take a live wire from the battery, touch it momentarily to the F terminal, removing it will cause a short Flash. Reconnect D and F. or you can check out A O Services web site-Fitting instructions for the V reg.
A O Services is at aoservices.co.uk
