Model 7 Data
Hi
I’m filling in a registration form for the DVLA to register a 1952 Model 7 plunger.
Can anyone help me with the dimensions ie length width and wheelbase.  Or point me in the correct direction to find it
Doug
Wheelbase is - 56"
Length as above plus 19" and one tyre height - probably plus 3"
Height above Ground 5 1/2" unladen
Weight - 421lb
I think you need to add 3 1/2 inches for the rear tyre
I forgot about the rear mudguard so add another 2 1/2 -3  '',
Data for 88 dommi .
Wheel base =55.5''
+2* rim radius= 19''
+ Front tyre= 3.25''
+ Rear tyre=3,50''
Total = 81.25''
Length = 84 ''
So add 2.75'' for the bit which sticks out the back of your model 7
