Head tightening
Just run the Atlas for the first time since rebuild. I have 2  different  tighten down patterns. One in the old Woolwich manual and a very different one in the Haynes thats repeated by Dunstall. Any Thoughts?, Normally I would ignore the Haynes , but then  not over impressed by the early Woolwich efforts with the Norton Engines either!!.
Looked in the technical section of this site?
Technical - heavy twins - cylinder head
2 patterns shown with some explanations for each.
Regards, George.
Thanks George, interesting ,  so its Hobsons choice then  !.  At least the Atlas now has compressions that feel equal both sides and does not leave a smoke trail. It clatters a bit more than it did ,perhaps the drag resistance of the new rings makes the piston rock a little more. Also filled it up with what 15/40 car oil was in the garage. An early change to 20/50 or 40 classic may damp it down.
hello with head Tightening there are two bolts behind each ear do these up HO sorry wrong head !! normally you start from inside out  to do up a cylinder head and outside in to undo a cylinder head as I was told many years ago witch works for me anyway  yours   anna J
