My 1960 Dommie headlight shell has 3 holes on the underside. 1 off 1 1/2" - main harness and one 1 1/8" and one 7/8".
One is for the speedo cable (I assume), what is the third one for?
I think the other is for the…
Zero setting
The small hole is for the speedo zero setting rod/cable for the odometer.
Headlight holes
Aaaaah thanks. It must have been lost in antiquity
Steve
Headlight holes
Oddly the larger 1.125" hole seems to be for the trip reset, and the smaller 0.875" is directly in line with the speedo drive cable.
I ordered 28mm and 22mm blind grommets.
Steve
I think the other is for the dipper switch / horn mini-harness from the left-hand end of the handlebar. Cheers, howard
