7" T.L.S Which supplier offers the best
Hello . My Norton Electra is in need of a 7" T.L.S. front brake. As my wrist has been operated on and the grip is alittle on the weak side.
I just want a plain brake, no vents ,no stiiffening plates. etc.
Are they suppliers or are they just agents. Do they supply the same article. How does their product vary in design and construction.
Which in your view is the best plain assembly.
Looking forward to your experiences in .T.L.S.
Closing now with kind regards to fellow members.
Martin Jones Hull
Hello Martin,
I am very new to the NOC and indeed Nortons. I do have a motley collection of British bikes--all with non standard from brakes--all but the recently acquired navigator with TLS Brakes.
I have a Rickman Triumph street mettisse with a Laverda TLS it is 8 inches or more and not hugely powerful (duff linings I suspect it was good with AM4 linings).
A 1964 T120 with a 1967 group typle 2LS front brake this is a good brake it is 8 inch but the same brake was made in 7 inches and fitted to BSA 250s 441s small Triumph twin and badge engineered 250s (new ones on sale).
I have a Bsa C25 with b40 engine with the TLS front brake from a Honda 250 K4--very good brake--there are many early Japanese 250/350s with 2ls brakes but--available at reasonable prices.
I have a Triumph 750 OIF with a the 8inch TLS brake from a Bridgestone 175 (the same as the 350--a flukely find of a rare bit)-- a very powerful brake.
If you do not mind the mix of bit--I'd look for a Ja bike one--they are old but probably cost less that a British one that is no better as brake.
JPA
If the Indian brake proved effective, why look further? You will certainly not buy a new T.L.S. brake, for 35 pounds, in the U.K.
Martin Jones Hull
Hello Martin why not go hydraulic brake with pit bike parts from eBay a hydrauic brake slave cylinder the screws in place of your old brake cable all you need is the brake lever set and you can fit one to the rear brake has well make it more afficant yours anna jAttachments
slave-clyinder-pit-bike-htm
Martin Jones Hull
That's a very good idea--I know several people who have done it especially with Aerials and AMCs for some reason. Some had hydraulic car drum brake plates fitted.
Hello John.
The back T.L.S. brake from India is a 6".and yes it works quite well. If I stamp on it, the rear wheel will tyre squeal on a dry road. but not strong enough to lock up. Its the front brake off Indias latest Bullet model.
If thay made an 8" T.L.S. I would get one tomorrow.
Thank you for your input.
Martin Jones
Martin
I've no direct experience of 7" TLS. The 8" TLS on my old 650 Triumph was a pretty good brake for its time and I would think that the 7" version referred to by John earlier in the thread would be almost as good. These are available from Burton Bike Bits for example:
https://www.britishbikebits.com/7-twin-leading-shoe-front-brake-assembly-bsa-triumph-1969-70#.WKwZGjjVqCk
Also there are 7" Royal Enfield ones from India on ebay, for example:
http://www.ebay.co.uk/itm/ROYAL-ENFIELD-7-INCHES-TLS-FRONT-BRAKE-ASSEMBLY-WITH-BRAKE-SHOES-AND-HARDWARE-/182367113957?hash=item2a75ed52e5:g:aSwAAOSwj85YO2H-
Apologies if you already have this info.
Andy
Martin Jones Hull
Hello Well with ThIS SLAVE CYLINDER YOU FIT IT IN PLACE OF YOUR OLD BRAKE OR CLUTCHCABLE AND THERE IS NO NEED OF ANY CAR PARTS the slave cylinder is a screw in fitting were the cable adjusteris, there is no need for any otherspecial parts . yours Anna J
Hello John.
Martin Jones
Hello Well it would of been a lot better if you had used a Norton Commando rear brake cable to keep ever thing close the to rear brake plate you then get a better pull has it is now you have a long shaft sick in out for the rear brake cam ,and when you use the rear brake that shaft for the brake cam then pulls forward just that bit to put the cam out of alinement the closer to the brake plate the better pull you have So then a short shaft for the cam would not have this extra force on it, the use of a Commando rear Bowen brake cable you can then take in behind the rear shocker via a stop clamp fitted to the rear swing arm so you can adjust the rear brake and do away with the rear brake rod, or go hydraulic slave cylinderwith a screw in fitting and fit twin master cylinder brake lever set one for the rear one for the front brake and one for the clutch to these mini slave cylinder are made so they fit any motorcycle with drum type brakes yours anna jAttachments
slave%20clyinder%20pit%20bike.htm
Have I missed some important bits here ? Surely the Electra has an 8" front brake?. I have just been up to my garage and both my De Luxe Navigator and the Standard Navigator have 8" SLS front brakes which I assumed was standard Dominator ? So any upgrade had to improve on this e.g TLS Commando . I don't think these are available from sources such as India. The 7" TLS from India are very cheap but they won't fit. Or will they ?
Patrick.
Patrick, you took the words right out of my finger! Having a lever with 7/8th gap between cable and pivot will help too.
dan
Patrick.
Hello What bar are you drinking Yes they will Fit with some work you have to use some brains yours anna J
dan
Hello Someone need to read what I have put on hydraulic brake conversion you simply do away with all your brake cables and fit hydraulic slave cylinders on rear brake front brake and clutch with universal hydraulic parts all flix pipes and all fitting can be fittedjust screw on fittings , bring you old drum brakes up to date and make them perform better your thinking the dark ages yours anna j
Previously Andrew Heathwood wrote:
Patrick
I reckon you're correct.
See this article http://ridermagazine.com/2009/07/14/retrospective-norton-electra-400-1963-1965/
And in Roy Bacon's Norton Twin Restoration Appendix 12 (pg 231) lists 8 x 1.25" front brake for 350 and 400 twins.
The rear brake on the 400 is 7 x 1.25" as opposed to 6 x 1" for the 350.
Andy
Hello I think these Motorcycle reporters need to do some research before putting their pen intogear Roy bacon is is not has accurate has you would think, and he not the only one Steve Wilson is has bad to along with otherS I have read their data is well out, LET ME SAY THIS THE FACTORY RECORDS ARE NOT THE BUILT DATE THERE THE DESPATCH DATE AND THE BUILD DATE CAN BE UP TO TWO WEEKS EARLIER OR MORE ! yours anna j
Patrick.
Hello What bar are you drinking Yes they will Fit with some work if you have to use some brains yours anna J
I'm new to this forum so somebody is gonna have to let me in on the joke.
This person rambling on above about hydraulic brakes and fitting a 7" backplate into an 8" drum has got to be having a laff, right?
It sounds like the ravings of a mad person.
Dearie me. An Electra should have a bog standard Dominator 8" sls brake fitted. So to go the TLS route all that's needed is a Commando type TLS brakeplate and cable. Simples. Or have I missed something here?
Martyn, Not quite! Anna might not write very clearly but she is an engineer, you can't question her enthusiasm and she has excellent knowledge of Nortons!!
Gordon I think the issue was that you can get cheap 7inch tls brake plates but not 8inch ones. Although I don't think it's clear whether the op has a wheel with a 7 inch brake or if he's mistaken! time will tell!
If only, with time you will get used to this sort of thing, unless she maintains her promise not to renew her membership in march.
Hello All
This link is to an advert showing an Electra and referring to 'full-hub front and rear brakes as big as those on the 750cc Atlas'
http://www.classicbike.biz/Norton/A_Link/1960s/63Electra400-Ad.pdf
That looks like 3 independent sources indicating that the standard brake was an 8" at least at sometime in the production of Electras.
Obviously owner needs to check what's fitted and go from there.
"I'll get me coat."
Andy
Charles
What's wrong with what Anna has written? She's suggested going hydraulic. No prob there. She's also assuming that the Op is right and he has s 7" brake. We've assumed he is mistaken and it's a 8inch brake. I've never spoken to her but think the club will be worse off without her.
Nothing personal, but comments like ' what bar are you drinking at and you have to use your brains' do sound a bit arrogant and might intimidate those who are not used to her ways.
Of course it is possible to convert from cable to hydraulic action, but I wonder whether you would want to. These are old bikes and maintaining there original spirit is important to some owners.
There were 3 posts last week on Britbike showing hydraulic conversion to a B50 8" TLS by Mead Tomkinson in the 70's when they raced B50's, no objection from anyone just thanks for posting details.
hello nothis was a bit of a banter do not take it personalbut your still not understanding me. I was not saying anything about the 8-inch front wheel drum were talking about the rear wheel only here TLS conversion by using a royal Enfield front TLS7-inch brake drum to fit in the rear hub !!!! and a Commando Rear Bowen Brake Cable so it fits behindthe shockerand not in front and you need to make up a clamp fitting adjuster for the short rod end that goesinto the rear brake lever now ARE YOU READING me OR you can get a universal mini slave cylinder with a screw in fitting that will go in place where the brake cable adjuster was now do you all understand this And this Slave Cylinder will fit all 3 rear clutch and Front Brake its has a Screw in Fitting yours anna j Attachments
slave-clyinder-pit-bike-htm-htm
I understand what she is saying, the only issue is that the original post was about a front brake and Anna was talking about a rear. But the same applies to the front, and if your hands are weak fitting hydraulics so you can still ride is a small price to pay in my book
dan
I don't think there is anyone here reading that does not understand what she is saying/repeating over and over (seven times). I just don't think people appreciate being spoken to like idiots with their implied lesser qualifications.
Going hydraulic maybe a legitimate conversion for some that don't mind putting chinese pitbike parts onto their venerable nortons, having that option jammed down yer throat several times and then having someone assume you haven't understood because you haven't agreed is a bit much.
1st law of thermodynamics indicates that energy put into a system will be transferred effectively minus losses, in this case frictional i.e. cables/linkages. Hydraulic systems do not create stronger hand muscles. Pivot distances make a huge difference as has already been mentioned. Modern teflon lined cables are very good, very low friction, do not leak fluid, very reliable, look correct. Sort out the fundamentals of why the brake is poor first (crummy cable, crap linings, bad adjustment etc.) before trying to sidestep around the problem with miracle chinese products from ebay.
Why do we ride our nortons anyway?Hondas have hydraulic brakes already, get a honda.
This is wildly off topic now, the OP asking which TLS backplate could be used in the Electra drum, obvious answer being the commando backplate, being a straight swap. Unfortunately vents and holes abound and it certainly couldn't be accused of being plain.
I can't attest to the quality of the pit bike hydraulics but they may well improve the leverage,
anyway hydraulics on a Norton is a matter of choice and they look ok on this one!
Norvil do the TLS 8" brake in plain form:
http://www.norvilmotorcycle.co.uk/064281.htm
And for some weird reason (might be a typo!) it is cheaper with the stiffening kit!
(ps Martyn - some of the original confusion probably arose from your message title: Re: 7" ... brake - do you really mean that or as both Patrick and Gordon have pointed out - doesn't your bike have the original 8" size?)
Incidentally - on hydraulics:
An SLS brake has both shoes pushed the same distance at the same time. So both theleading and trailing shoes are forced by the mechanical cam to wear at the same rate so they must both provide the same friction force. But with hydraulics, one will self-servo and one will not. So they will wear at different rates. This is because hydraulics apply a force, whereas a cam provides a displacement.
Martyn's point about not getting something for nothing is well made! Oneefficiency benefit from hydraulics is to remove cable and cam friction (and replace it by some smaller friction in the seals). The other is that the relationship between effort and brake force remains the same as the shoes wear because there is no cam angle to change. Hydraulics ismore convenient to a designer because he does not have to concern himself about clear paths for tidy cable runs.
You need to remember that altering the braking system, whether TLS or hydraulic, should be discussed with your insurer. They will probably be OK with fitting a commando TLS, but may well be very unhappy with a home made hydraulic system. Failure to notify will almost certainly invalidate your policy.
Hello At last I have rattled someones cage and got some feedback if you had of put all this in first i would of not answered7 timesthen ! and rightlyyou have made some good points of view but it took you long enough to get it off your chest, well done keep up the good work yours Anna J
Martin Jones Hull
Hello Fellows.
I got it wrong. I must take more water with that Irish Whisky. Its 8" up front and 7" at the rear end.
The 7" TLS kit from India at £39 with included carriage by air freight. Works the rear end just fine.
The 8" TLS for the front . The saga is that only Norvil seems to sell the plain brake plate assembly.
Including carriage and vat its 80 pence short of £400.
Not sure if I will bother. Might just fit a longer brake lever. Ha ha.
Regards to all fellow members.
Martin Jones Hull
David ... on hydraulics, yes and no! The convertion here is using a slave cylinder to push the cam so it's no different to a cable, and the ease of applying force is dependant on the leverage, hence the difference between a 1 1/4 in and a 7/8 in pivot.
I have no idea what the ratio is for these small pit bike hydraulics but know that other members have used them with success on clutches.
Charles is right to say you need to inform your insurer
That's interesting, Dan. So if this conversion does not involve putting a slave inside the drum like a car (older car...), it only replaces the cable friction and not the cam friction? Sounds like a lot of effort for very little return to me - but I suppose I'd need a 'double blind trial' to find out.
I do have 7/8 lever pivot on my TLS Dommie brake. It is fine although has a tendency to jam on when starting after being left for a few weeks. I know that next time I get the bike out I shall ride up the road (the STRAIGHT road) very slowly and try the brake. It will squeal and stick until I've done couple of hundred yards. Only then will it be safe to use. If I rashly go east instead of west, I will fall off on the curve at the end of the road. Again.
Point taken, but "maintaining original spirit" (and even more so, maintaining original parts) will be harder if one has stuffed the front end through failing to stop quickly enough ...
Given that the Electra has a modest weight, about 50 lbs less than a Dominator, and modest performance, 80-85 mph top speed+ a rather good 8'' front brake , I think that stopping quickly should not be a problem.
There is an informative article on Sammy Miller's Electra in the March ' Classic Motor Cycle'.
Roy Ponting, who tested it says that he had no complaints about the brakes.
I see the OP has abandoned this thread now and started a new one so it's probably ok to go off on a tangent....
The 8" SLS can be made to work reasonably well despite the shortcomings of the SLS concept.
The uneven wear of the shoes causes a problem when they are essentially linked by the single cam. Because the trailing shoe wears slower than the faster wearing leading shoe (that does possibly as much as 80% of the work), eventually the pressure the cam is able to apply to the leading shoe is compromised because of the fact that the trailing shoe isn't wearing as fast and is stopping the cam from rotating.
Car drum brakes don't suffer this because the hydraulic slave cylinder automatically compensates for this problem.
Changing the shoes around occasionally would help mitigate this situation or having a floating backplate.
Following (or rambling) on,
It's probably feasible to throw the trailing shoe away and just rely on the leading shoe, the trailing shoe just causes a problem. Anyone that has had to hold a bike pointing uphill on the front brake if the bike is fitted with a big 4LS will have experienced that even four trailing shoes don't do jack..
Hello Something you maybe interestedin In my Amal parts book It tells me that amallevers Part number 18/755 ball end lever righthand. with 7/8ths bar fitting and 1.1/16 pivot between pivot and barrel hole for the cable end, At Monty'sClassic on Ebay Number 132039539041 you find lever for brake and air lever 7/8 bar fitting and 1.1/16 pivot which is the largest pivot you can get hope this may help yours anna j
Anna
although a 1 1/16 gap will give a longer movement of the cable a smaller gap, i.e. 7/8th will make for a much easier action because leverage is improved.
Dan
Have a good look at the pit bike stuff before you commit to buy. They have no bleed nipple so are very difficult to bleed. I tried fitting one to my Commando clutch, and one person on this forum has managed this, but I could not get enough travel in the pull rod to disengage the clutch. Bare in mind most of these are sold as clutch levers so you would have to find another master cylinder. The pit bike stuff is smaller than standard Jap hydraulic fittings. Mine is in the pending drawer, probably shortly to be the binUndecided
Before anyone modifies their brake system and especially if they change to hydraulics, check that your insurance company are happy with this and that you do not infringe construction and use laws.
I really cannot see why you would want to go hydraulic with an Electra. What next, double ceramic discs with 4 pot calipers!
It should not be difficult either to get the big SLS system to work well or to use a cable operated Norton TLS system from ,say, a commando
