Hello. I have the original clutch cable still for the above bike but the outer cable has perished and the inner cable has become to short for the cable to work effectively. I need to find a place where I can get one remade using the original cable ends I have with preferably a nylon lined outer cable for a smoother action. Any ideas. Glenn
The man you want is Mr Joh…
Thanks Ronald. I will give…
Thanks Ronald. I will give him a call. Best wishes, Glenn
The man you want is Mr Johnson of J.J.Cables-01926 651470
