Commando gear ratios using various boxes and sprockets and speeds per 1000 r.p.m.
The same AMC gearbox was used on all Commandos, the only change being that from 1974 onwards there was a small difference in the 2nd. gear ratio (not shown in m.p.h. tables). The overall gearing is also affected by the size of the final drive sprocket; usually 19, 20 or 21 teeth, occasionally 22. |
Standard | RGM Close Ratio (with Kickstart) |
RGM Close Ratio (no Kickstart) |
Quaife Close Ratio (Road) |
Quaife Close Ratio (Racing) |
STANDARD - Ratios | ||||||||
SPROCKETS | Engine 26 teeth |
Clutch 57 teeth |
Rear wheel 42 teeth |
Rear wheel size 19" x 4.10 81" circ. |
FINAL DRIVE | 19 TEETH | 20 TEETH | 21 TEETH | 22 TEETH | ||||
GEAR | mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
1st. | 6.19 | 37 | 6.52 | 39 | 6.85 | 41 | 7.17 | 43 |
2nd. | 9.29 | 56 | 9.78 | 59 | 10.27 | 62 | 10.76 | 65 |
3rd. | 13.01 | 78 | 13.69 | 82 | 14.38 | 86 | 15.06 | 90 |
4th. | 15.83 | 95 | 16.66 | 100 | 17.49 | 105 | 18.33 | 110 |
STANDARD - Teeth | ||||
GEAR | 1st. | 2nd. | 3rd. | 4th. |
Mainshaft | 14 | 18 | 21 | 23 |
Layshaft | 28 | 24 | 20 | 18 |
Ratio | 2.556 : 1 | 1.704 : 1 | 1.217 : 1 | 1.000 : 1 |
Mainshaft 2nd. gear was 19 teeth from 1974 onwards; ratio 1.614 : 1 |
RGM CLOSE RATIO (Kickstart) - Ratios | ||||||||
Clutch 57 teeth |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
1st. | 7.72 | 46 | 8.13 | 49 | 8.53 | 51 | 8.94 | 54 |
2nd. | 11.31 | 68 | 11.90 | 71 | 12.50 | 75 | 13.09 | 79 |
3rd. | 13.76 | 83 | 14.49 | 87 | 15.21 | 91 | 15.94 | 96 |
RGM CLOSE RATIO (Kickstart) - Teeth | ||||
Mainshaft | ||||
Layshaft | ||||
Ratio | 2.05 : 1 | 1.40 : 1 | 1.15 : 1 | 1.00 : 1 |
RGM CLOSE RATIO (no Kickstart) - Ratios | ||||||||
Clutch 57 teeth |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
1st. | 8.79 | 53 | 9.26 | 56 | 9.72 | 58 | 10.18 | 61 |
RGM CLOSE RATIO (no Kickstart) - Teeth | ||||
Mainshaft | ||||
Layshaft | ||||
Ratio | 1.80 : 1 | 1.40 : 1 | 1.15 : 1 | 1.00 : 1 |
QUAIFE CLOSE RATIO (Road) - Ratios | ||||||||
Clutch 57 teeth |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
1st. | 6.71 | 40 | 7.07 | 42 | 7.42 | 45 | 7.78 | 47 |
2nd. | 9.57 | 57 | 10.08 | 60 | 10.58 | 63 | 11.08 | 66 |
3rd. | 11.72 | 70 | 12.33 | 74 | 12.95 | 78 | 13.57 | 81 |
4th. | 14.31 | 86 | 15.07 | 90 | 15.82 | 95 | 16.57 | 99 |
5th. | 15.83 | 95 | 16.66 | 100 | 17.49 | 105 | 18.33 | 110 |
QUAIFE CLOSE RATIO (Road) - Teeth | |||||
GEAR | 1st. | 2nd. | 3rd. | 4th. | 5th. |
Mainshaft | 14 | 17 | 19 | 21 | 22 |
Layshaft | 27 | 23 | 21 | 19 | 18 |
Ratio | 2.357 : 1 | 1.654 : 1 | 1.351 : 1 | 1.106 : 1 | 1.000 : 1 |
QUAIFE CLOSE RATIO (Racing) - Ratios | ||||||||
Clutch 57 teeth |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
mph per 1000 rpm |
mph @ 6000 rpm |
1st. | 7.97 | 48 | 8.39 | 50 | 8.81 | 53 | 9.23 | 55 |
QUAIFE CLOSE RATIO (Racing) - Teeth | |||||
Mainshaft | 16 | 17 | 19 | 21 | 22 |
Layshaft | 26 | 23 | 21 | 19 | 18 |
Ratio | 1.986 : 1 | 1.654 : 1 | 1.351 : 1 | 1.106 : 1 | 1.000 : 1 |
