P1
P2
P3
P4
Frame Welding
A review of correspondence from NOC-L
A short note on welding Commando frames
Welding Commando frames
I'd asked what Commando frame tubes were fabricated from, as I had some weld repairs to do on my 1971 model. I received a couple of replies that were pretty much diametrically opposed, and I couldn't locate any information in my library, so I did some first-hand research.
The X-ray diffraction tester in my plant's materials testing lab. says that the tubes are fabricated from mild steel; very similar to C-1020 hot-rolled carbon steel. We successfully completed several weld repairs on the swinging arm today using a MIG process with mild steel filler rod.
Mark Smith (mjsmith@execpc.com) on NOC-L 9th. Jul 1997
